Joined: 8/16/2019(UTC) Posts: 355  Thanks: 80 times Was thanked: 24 time(s) in 19 post(s)
Hi all, I've probably figured this out but I thought I'd ask anyway. I'm using vMix HD 23.0.0.60 x64 so I only have one output (I just can't afford the whooping huge price for the 4k version - I only do this as a hobby and don't make any money from my streams).
Anyway, I would like to send a different output to Skype while still streaming output one for my viewers, is this possible in the HD version?
Thanks in advance.
You have been a member since:: 8/29/2020(UTC) Posts: 6  Was thanked: 1 time(s) in 1 post(s)
As you said, you only have 1 output.
That output is your output.
...that said, depending on what specifically you want to do, it might be possible. Something like sending your main camera feed into Skype, rather than your main output, is something that might be possible, depending on your particular setup but it's something that'd need to be done outside of vMix, either with physical hardware or non-vMix software. (Though, honestly, depending on your setup, if that's what you're going for, it'd probably be easier to just get a cheap HD webcam, stick it somewhere discrete, and feed that into Skype.)
 1 user thanked WaltG for this useful post.
Joined: 2/23/2017(UTC) Posts: 189  Thanks: 1 times Was thanked: 52 time(s) in 42 post(s)
If you are not using fullscreen output then send your desired input to the fullscreen output - you must have external monitor or monitor emulator connected to the graphics card. Send your desired audio mix to bus A.
Install NDI tools. Use NDI Scan Converter to capture your second screen. Use NDI Virtual Input to get the Scan Converter NDI output and for audio vMix Audio Bus A.
Skype should see your NewTek NDI input.
If you just want to send camera input to Skype then enable NDI outputs of the cameras (Settings -> Output) and then use NDI Virtual Input to get it into the Skype.
 1 user thanked MartLeib for this useful post.
Thanks for all the idea, I plan to send just the comments (output>input 3) for example, but I'll give that a go.
Originally Posted by: MartLeib  If you are not using fullscreen output then send your desired input to the fullscreen output - you must have external monitor or monitor emulator connected to the graphics card. Send your desired audio mix to bus A.
If you just want to send camera input to Skype then enable NDI outputs of the cameras (Settings -> Output) and then use NDI Virtual Input to get it into the Skype. Worked perfect, thank you.
