share24
#1 Posted : Friday, August 28, 2020 3:15:58 AM(UTC)
share24
Is it possible to group overlays so when I click on either 1, 2, 3 or 4 they all appear or disappear?
For instance, when streaming, I'll typically have at least one sponsor logo and a scoreboard.
Right now, I set them up as individual overlays and click on them one at a time to make them appear or disappear. That becomes burdensome when playing a video or adding another graphic where I don't want the overlays.
Here's a screenshot of my setup:
[img=https://ibb.co/h2qfmyc]Screenshot[/img]
Right now, each image is its own overlay.
I'd like to set them all up under one, for instance the #1 overlay, so when I click the 1 it appears or disappears.
#2 Posted : Friday, August 28, 2020 4:28:03 AM(UTC)
You can either use triggers or shortcuts to do this.
You can also design your titles so that they integrate everything you need at once... For instance have your sponsor logo associated to the scoreboard directly.
