need help for basics effects
Good evening, I have BASIC HD version, and I am limited at 4 inputs. Actually, to incrust a text, I use title input, but it use one input. Is it possible for example in camera input, to add a scroll text, without use Input texte? Regards
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: Franck  Good evening, I have BASIC HD version, and I am limited at 4 inputs. Actually, to incrust a text, I use title input, but it use one input. Is it possible for example in camera input, to add a scroll text, without use Input texte? Regards
And where would your text come from then ?
Originally Posted by: doggy  And where would your text come from then ? I don't know, it is my question for others solutions peharps?
Originally Posted by: Franck  Originally Posted by: doggy  And where would your text come from then ? I don't know, it is my question for others solutions peharps? - Use a second computer with Basic HD that inputs the video , puts text on it and send that via NDI to your work computer (you gain 4 inputs and have now have one left on your working one) or - upgrade if you need more than 4 inputs (doubt you will use all 1000 of them)
thank's for this explanation and solution. At this time, it is dammage, there are not update between BASIC HD and HD, the difference price is very important for amators. Regards
