Send output VMIX on second monitor
Rank:: Member
Morning
On my video card, I have two monitors. Principal N°2 > for VMIX Second N°1 > for my video
Impossible to send vmix flux on second monitor.
In setting display, I have choice N°1, but nothing on display. Can you help me please? Regards
Joined: 7/28/2019(UTC) Posts: 351  Location: Santa Rosa Thanks: 1 times Was thanked: 53 time(s) in 51 post(s)
It sound like you want to send 2 separate feeds to 2 additional monitors?
First, confirm that both monitors are set to extended and that you are seeing an image (desktop background).
Then in VMix settings>Display>Fullscreen
Set "display 1" to 2, and "display 2" to 3 (Note that 1 is your own desktop)
Then close settings and press Fullcreen at the tope of VMix. You can also pick what you want to send to those displays from the Fullscreen dropdown.
Rank:: Member
Hi Vence, Thank you very much, it is ok now ;-)
