Craig R
#1 Posted : Thursday, July 10, 2014 9:05:14 AM(UTC)
Craig R
I am having alittle issue with The Vmix Desktop Capture and hope for some pointers
We have a number of lecture theatres and I have the Vmix Remote Desktop Capture Running on them fine.
When I pick the input Device Desktop capture only the computer running Vmix is shown with an IP address of 0.0.0.0
If I enter the Ip Address of the computer running Vmix Desktop Capture it connects fine, but I would like to get a list of computers from all the different lecture theatres running Vmix Desktop Capture.
If I turn off the Firewall on the computer running Vmix all the Lecture Theatre computers appear in a list which is great, But I can't have the firewall switched off My IT Dept will not allow this.
I did get them to configure the firewall to Allow incoming and out going for Vmix but still no Joy the Lecture Theatre computers list did not show up
Is a secondary program running listening for the Vmix Desktop Capture software that I need to Allow through the Firewall ? or a Service I need to let through
The Reason I would like a List of Computers instead of entering the Ip Address each time is because I need the Vmix System to be Idiot Proof as some members of staff are not as up to speed as other members of staff is a nice way of putting it.
Craig Rennie
#2 Posted : Thursday, July 10, 2014 11:10:58 AM(UTC)
Was thanked: 4733 time(s) in 1623 post(s)
Make sure the firewall allows UDP inbound on port 20555
This is what desktop capture notifications are sent on.
ClementN on 7/10/2014(UTC)
Craig R
#3 Posted : Thursday, July 10, 2014 1:49:01 PM(UTC)
Craig R
Thanks Martin My IT Tech Guy said he had already enabled UDP on port 20555 and it still did not work so we dug alittle deeper and for some reason there were 2 instances of Vmix in the Firewall one enabled and one blocked.
Bit of a head scratcher why there were 2 instance's in the Firewall but once the blocked instance was deleted all working Great.
Thanks Martin
Craig R
