Hardware Compatibility
Funciona Capturadora Kodicom con vmix? - Works with Vmix Kodicom Capture?
Rank:: Newbie
Hola! como va? quisiera saber si la placa kodicom de 4 canales es compatible con vmix? creo que el modelo es kodicom 4400r... Acá les dejo un link de la placa que quisiera adquirir articulo.mercadolibre.com.ar/MLA-5106547...ps-1-audio-tvout-_JM
Desde ya gracias y espero su ayuda!!
-----------------------------------------Translation---------------------------------------------------
Hello there! as it goes? I wonder if the plate kodicom 4CH Vmix supports? I think the model is kodicom 4400r ... Here I give you a link to the board that would purchase articulo.mercadolibre.com.ar/MLA-5106547...ps-1-audio-tvout-_JM
From already thank you and I hope your support!
