ben1000
#1 Posted : Sunday, August 16, 2020 12:04:49 AM(UTC)
ben1000
Sorry if this has already been suggested..
One feature that would make a huge difference for me is to easily add an adjustable border to an input, so that if it's zoomed less than 100, the border shows up around the image. Ideally this border should maintain even if the input is cropped, so a cropped and zoomed input would still have the same border around its edge...
I am currently able to do this through some complicated multi-layering and triggering, but I'd rather just have it as a check box option that could be easily adjusted and turned on or off..
Thanks!
Best,
Ben
#2 Posted : Sunday, August 16, 2020 12:41:42 AM(UTC)
Yes it has
Also with cropping ?? not even the PIP overlay handles cropping for the border
full colored layer behind image and simultaneously zoom can crop that one works
but there is a rumor for v24
