MattGrover
#1 Posted : Monday, August 10, 2020 7:26:08 PM(UTC)
MattGrover
Hi all,
I've recently picked up a SubZero MIDI MiniControl (also known under Worlde and Pyle branding) for some very basic surface control.
I've got the audio faders and gain knobs doing what I want and managed to assign the two bottom left buttons to transitions, however, I've been trying to map the buttons beneath the faders to either toggle the audio AutoMix or simply toggle audio on/off, but no matter what I do it seems they need a double press to trigger the shortcut each time, which then means the buttons end up lit up/not lit up on the wrong states.
Is anyone else using these surfaces and have any advice?
Cheers
Matt
