beedegee
#1 Posted : Monday, August 10, 2020 2:16:05 AM(UTC)
beedegee
Hi there.
Is there a trigger to change the category color of an input?
I would like to make different 'reset' inputs with loads of triggers to define all kinds of stuff. And it would be awesome if I could change category color so the user can only see the inputs needed for that part of the show.
I can only find the Selectcategory, but thats to change the category of what your are viewing. I want to be able to change the category of a input with a trigger.
Also, is there somewhere an overview what each trigger does? I have the idea there are tons of usefull triggers but I don't know what they do.
#2 Posted : Monday, August 10, 2020 3:21:23 AM(UTC)
A trigger can do whatever a shortcut can do basically (exceptions confirm the rule), one can check that list by opeing shortcuts editing or the list in the vMix help files
elvis55
#3 Posted : Monday, August 10, 2020 3:50:13 AM(UTC)
elvis55
Switzerland
I don't quite understand what you want to achieve?
As doggy has already written, you can achieve a lot with triggers or shortcuts.
I'm not sure if you are looking for something like this:
Shortcuts
SelectCategory
Change to Category according to Value (All,Red,Green,Orange,Purple,Aqua,Blue)
Value = Category
beedegee
#4 Posted : Tuesday, August 11, 2020 8:32:14 PM(UTC)
beedegee
I'm making a daily show with dozens of inputs/presets. But a lot of them won't be needed every day. Day one only inputs 30-40. Day two only 50-60. etc.
So I was planning to easily switch between the category color of that input, with a shortcut/trigger.
For Day one I would change category of input 30-40 to RED, leave 50-60 black.
For Day one I would change category of input 50-60 to RED, change 30-40 to black.
etc.
By default I would only see the RED category inputs. If make a lot of triggers, changing the color of the inputs I want to use, to RED, I only would see the inputs I need for that show.
#5 Posted : Tuesday, August 11, 2020 8:42:18 PM(UTC)
Triggers are used to respond to an input action
Shortcuts are functions that can be called with triggers, keys, Midi controllers , scripts etc
that said IMO even if a shortcut would exist the time it would take to specify all the individual commands to move the inputs to a category might as well be used to just move them (what is simpler than just dragging them?) or just the needed ones loaded and save as a preset
beedegee
#6 Posted : Tuesday, August 11, 2020 9:03:31 PM(UTC)
beedegee
Also, is it possible to make a shortcut with a combination of buttons?
For example CTRL + T.
I want to make a shortcut that activates a valid test on the 2 outputs. But for obvious reasons I want to be sure you don't press that shortcut accidentally.... 🙃
#7 Posted : Tuesday, August 11, 2020 9:10:21 PM(UTC)
Have you checked ?
beedegee
#8 Posted : Tuesday, August 11, 2020 10:31:27 PM(UTC)
beedegee
Have you checked ?
Wel....
I checked the manual. Again.
I tried making a shortcut, press find, press CTRL and T it only shows T. Or CTRL if that is the key I release last.
I've searched Google.
I've looked a 10 minute vMix Tutorial on YouTube.
So I think I checked.
#9 Posted : Tuesday, August 11, 2020 10:49:07 PM(UTC)
and the conclusion was ?...........NO!
unless you use something like autohotkey (3rd party) and alike
Bonbondotkom
#10 Posted : Thursday, July 27, 2023 11:14:14 PM(UTC)
Bonbondotkom
Philippines
how do I map a red category input to a button and the button is a dynamic input and it depends on SelectCategory shortcut? so if i select Red, the. the button is input1(red) and if i select yellow, the button is input7(yellow)
thanks!
#11 Posted : Friday, July 28, 2023 12:25:24 AM(UTC)
thanks!
Fail to see the usefulness or logic of this as in what criteria would define which input it is be based on the category selected ( a bit more details in the purpose?).
Categories are basically just a display filter (only) of all the inputs.
but if you want to know to which categorie an input belongs one retrieve that from the (last) preset file with a script and do your logic there
Bonbondotkom
#12 Posted : Friday, July 28, 2023 6:26:17 AM(UTC)
Bonbondotkom
Philippines
thanks!
I am using a Keyboard. logic's like this:
F1=Function=SelectCategory&Value=Red
F2=Function=SelectCategory&Value=Green
F3=Function=SelectCategory&Value=Orange
F4=Function=SelectCategory&Value=Purple
D1=Function=PreviewInput&Input=First Input shown in Selected Category
D2=Function=PreviewInput&Input=Second Input shown in Selected Category
D3=Function=PreviewInput&Input=Third Input shown in Selected Category
D4=Function=PreviewInput&Input=Fourth Input shown in Selected Category
D5=Function=PreviewInput&Input=Fifth Input shown in Selected Category
D6=Function=PreviewInput&Input=Sixth Input shown in Selected Category
D7=Function=PreviewInput&Input=Seventh Input shown in Selected Category
D8=Function=PreviewInput&Input=Eighth Input shown in Selected Category
D9=Function=PreviewInput&Input=Ninth Input shown in Selected Category
Example scenario:
Input1 to Input9 are Red Category
Input10 to Input18 are Green Category
Input19 to Input27 are Orange Category
Input28 to Input36 are Purple Category
I press F3 to Show Inputs in Orange Category
Then these should what D1 to D9 would do:
D1=Function=PreviewInput&Input=Input19
D2=Function=PreviewInput&Input=Input20
D3=Function=PreviewInput&Input=Input21
D4=Function=PreviewInput&Input=Input22
D5=Function=PreviewInput&Input=Input23
D6=Function=PreviewInput&Input=Input24
D7=Function=PreviewInput&Input=Input25
D8=Function=PreviewInput&Input=Input26
D9=Function=PreviewInput&Input=Input27
After that
I press F4 to Show Inputs in Purple Category
D1=Function=PreviewInput&Input=Input28
D2=Function=PreviewInput&Input=Input29
D3=Function=PreviewInput&Input=Input30
D4=Function=PreviewInput&Input=Input31
D5=Function=PreviewInput&Input=Input32
D6=Function=PreviewInput&Input=Input33
D7=Function=PreviewInput&Input=Input34
D8=Function=PreviewInput&Input=Input35
D9=Function=PreviewInput&Input=Input36
After that
I press F1 to Show Inputs in Red Category
D4=Function=PreviewInput&Input=Input4
D5=Function=PreviewInput&Input=Input5
D6=Function=PreviewInput&Input=Input6
D7=Function=PreviewInput&Input=Input7
D8=Function=PreviewInput&Input=Input8
D9=Function=PreviewInput&Input=Input9
After that
I press F2 to Show Inputs in Green Category
D1=Function=PreviewInput&Input=Input10
D2=Function=PreviewInput&Input=Input11
D3=Function=PreviewInput&Input=Input12
D4=Function=PreviewInput&Input=Input13
D5=Function=PreviewInput&Input=Input14
D6=Function=PreviewInput&Input=Input15
D7=Function=PreviewInput&Input=Input16
D8=Function=PreviewInput&Input=Input17
D9=Function=PreviewInput&Input=Input18
Is it doable in scripting without using MoveInput? I don't want to change the input number
#13 Posted : Monday, July 31, 2023 7:34:45 PM(UTC)
D9=Function=PreviewInput&Input=Input18[/color]
your post allready shows a logic you can use.
each color selection represents input 1 + (9*x)
so when you select a category at the same time save a value representing the category ( as X) in the form of a value from 0 to 9 ( can store it in dynamic values)
so when calling for a preview retrieve the value and use function PreviewInput&Input=input 1 + (9*value) ..... PreviewInput&Input=input 9 + (9*value)
Bonbondotkom on 8/3/2023(UTC)
Bonbondotkom
#14 Posted : Thursday, August 3, 2023 2:15:02 AM(UTC)
Bonbondotkom
Philippines
Thanks doggy, i appreciate it. sorry for the redundant post in another topic. i just deleted it.
Bonbondotkom
#15 Posted : Monday, August 7, 2023 7:16:40 PM(UTC)
Bonbondotkom
Philippines
etc.
i guess maybe just put:
Day one, input 30-40 to RED
Day two, input 50-60 to GREEN/ORANGE/BLUE (which ever color)
Guest (13)
