ballsfox14
#1 Posted : Sunday, August 9, 2020 12:58:59 PM(UTC)
ballsfox14
El Salvador
Hello good evening, I hope it is the correct discussion to solve my problem, I am already desperate since I can not find the problem
I work in a TV channel, and I am in the area of the channel where the programming is done, it turns out that everything was going well, but today I no longer explain, when I'm at home sometimes I do the programming remotely, we use anydesk to access, It turns out that when I enter, the programming changes by itself and I don't understand why and today an example was a movie starting when I remotely entered and changed only to another programming.
I clarify we do not use triggers
I do not know if I understand I hope your answer soon and thank you
