Don't know how to describe this
Joined: 4/24/2020(UTC) Posts: 9  Location: Surrey Thanks: 2 times
Hi I don't know how to describe this but...
when going through a sequence of inputs one after another via my Elgato mini Stream Deck, in a sequential fashion; the preview switches back to a prior input in the sequence instead of going on to the next input in the sequence when pressing the next item.
I presume this is intentional in vmix for some reason, and if so, is there a way to stop this and just have vmnix go through the inputs sequentially.
I know there is a playlist function but I don't want to have to do that when it should be straightforward to go through this in order.
Any help appreciated. This is for a church service so I need it to be as easy as possible for anyone in charge of the service and so they won't get confused and transition an input that has jumped backwards.
Many thanks
@ Osprey
What Shortcut(s) are you using?
Ice  shortcuts.PNG (28kb) downloaded 0 time(s).
Is there a problem with my shortcuts?
