Salter
#1 Posted : Wednesday, July 29, 2020 8:36:48 AM(UTC)
Salter
Canada
Just wanted to share this little trick I found that makes it possible to use my teleprompter (TP) setup to view vMix callers when looking at my recording camera. It's probably known to most of you, so no need to read further if that's the case.
My TP setup allows for up to 11" or so tablet to be used, but I opted instead to use a 10"(1200x800) monitor that Windows recognizes as a 2nd monitor. I found this solution to be superior to the use of a tablet, for many reasons which I won't get into here. But the cherry on the cake is vMix ability to send any of the inputs or Multiviews to this 2nd monitor. This means that I can look straight at my main camera and see my vMix caller/s right in front of the lens, Instead of side glancing my main monitor. Makes for a much more natural interaction while remaining focused on the audience. I love it.
Salter.
