tsioukas
#1 Posted : Monday, July 27, 2020 7:37:40 PM(UTC)
tsioukas
Greece
During a conference we don’t have fixed participants all the time. If we want to have multiple participants to present from their places and at the same time to record their feeds for post production, multicorder doesn’t work as it expected. We need to add on the fly new VMix calls and the only option is to stop / check new VMIX call and start again the recording. And here is the problem, if we also record the conference we cut and lose a part of the output or from a simultaneous call.
The only solution that we found is to have 2 VMix instances and to use one for the live and the other for the VMix calls (or Skype NDI calls). But this is tricky and complex. The other solution is to change input to a new VMIX Call, we found that it keep recording into a separate file, but it's also tricky because sometime we need disconnect from a call and make a new later.
So I suggest to add independent start and stop button for each input on MultiCorder and as a bonus to have an option to auto record all VMix calls that they connect to project.
Thank you in advance
