Feature Requests
Export import Title/XAML presets
Joined: 2/18/2014(UTC) Posts: 1,813 Location: Stockholm
Thanks: 138 times Was thanked: 292 time(s) in 246 post(s)
I guess Title/XAML presets are saved within vMix's preset files. Even so, it is easy to hit the clear button by mistake, thus deleting a bunch of presets by mistakes. Furthermore, if it was possible to import presets, then it would be much easier to create/edit a large number of presets in another app (like Notepad).
Anyone else find this useful? (We are currently developing an external app that will manage presets, but it's perhaps not suitable for all)
Joined: 4/24/2014(UTC) Posts: 15 Location: Boston, MA
Now that I have had a chance to try out vMix, an Export (and import feature) would be fantastic.. To be able add a source by dragging-and-dropping a preset file onto the main window would be a huge benefit to me.
drjoeblack, I am not sure we are discussing the same thing. I am referring to presets, eg a number of Headlines and Descriptions for titles. Not "presets" in general. Perhaps you can explain your idea in greater detail.
In any case, seems the import/export I wished for is going to be available in v13 :) Thank you Martin!
Feature Requests
