Roger Anderson
#1 Posted : Thursday, July 16, 2020 4:55:10 AM(UTC)
Roger Anderson
When you record VMix Call inputs it will frequently crash MultiCorder. I have talked to support about this and they claim it's not a vMix problem, it's a problem with WebRTC but the crash is in the MultiCorder and it takes out ALL your recordings.
Support says:
If there is an invalid timestamp being sent from the source browser, which happened in this case, there is no way for the recording to recover hence the error.
This can happen for numerous reasons on the browser side which is why we don't support it.
The functionality is there mainly for users using vMix on both sides, as we can fully managing the call timing to make sure there is no bad signals being introduced into the stream.
We can't do that for every browser setup, so unfortunately the situation still stands that we don't support vMix Call with MultiCorder.
The workaround is to assign to alternate outputs, but that means you can't ISO more then 3 callers AND the alternate output takes up a lot more CPU so it's an issue.
