Green screen: different backgrounds for each camera
Hi vMix-folks!
I am looking for a solution with vmix (HD Version/Atem mini/Decklink 4K/Ultrastudio 4k mini): I have 2 or 3 cameras. And when switching the cameras, different backgrounds should be inserted (keyed) depending on the camera perspective.
Example (2 person talk in front of green screen) Background camera 1: long shot of the room Background camera 2: Halfway from the room from the perspective of the camera Background camera 3: Half close to the room from the perspective of the camera
Does somebody has any idea? Thanks in advance!
That's what a Virtual Set is designed for
Originally Posted by: DWAM  That's what a Virtual Set is designed for Hi Dwam! Thanks! Yes i know the virtual sets, but it is possible to customize them? I dont need a Studio. I will only use my background-pics. Best regards!
as explained in this video, there are empty templates that you can use with your own graphics for sure... just click the virtual set input and scroll the choice list !
Originally Posted by: DWAM  as explained in this video, there are empty templates that you can use with your own graphics for sure... just click the virtual set input and scroll the choice list ! THANKS!! I will try this.
