tomscott
#1 Posted : Sunday, July 5, 2020 5:20:56 PM(UTC)
tomscott
I have a scoring panel built in Ross Dashboard which is writing a XML.(looking at the XML via notepad I can see there is data in it)
When I browse in the vMix Data Source Manager I can see the XML file but it shows no data.
I am running the trial version of vMix as I wanted to see what the integration is like before purchasing.
Cheers
Tom
stigaard
#2 Posted : Sunday, July 5, 2020 6:51:59 PM(UTC)
stigaard
Denmark
With a XML file you select a XPath to specifically read data from. Look in the XML and use https://www.w3schools.com/xml/xpath_syntax.asp to determine which path you should use.
