HWL1223
#1 Posted: : Sunday, June 22, 2014 9:29:42 AM(UTC)
HWL1223
so I can launch the audio mixer and the streaming module when Im using low resolution screens in the field.
Also, the multiple bit rate stream name function for AFLME; is that fixed?
Also, you know how Input Photos has the Image Sequence option; can you add that for Video files? (so it too becomes a sort of scheduler or program player). OR - is that what the List is able to do but where do you store a copy of it?
Also, an external trigger (GPI?) based on a video clip (real time point or time code) that can trigger an HTML or other event.
