fordry
#1 Posted : Tuesday, June 17, 2014 5:59:51 PM(UTC)
fordry
Would be nice if setting the processor priority for FMLECmd.exe in the streaming setup was an option just to add a layer of stability to the streaming to try to prevent any occurrences of dropped frames. Can be manually set in Taskmgr but it would be nice to have it be a saved setting that vmix uses when it starts up the streaming as Windows doesn't save the priority setting.
PFBM
#2 Posted : Tuesday, June 17, 2014 6:23:16 PM(UTC)
PFBM
hi !
i will be testing this alternative streaming encoder:
https://obsproject.com/
it can use nvidia gpu to do the encoding process.
https://developer.nvidia...m/nvidia-video-codec-sdk
Cheers,
PFBM
