Joined: 9/17/2013(UTC) Posts: 173  Location: Norway Thanks: 10 times Was thanked: 56 time(s) in 29 post(s)
Hey all,
As a satisfied owner of three BlackMagic Intensity Pros and a USB3 Shuttle, I found a cheap used Matrox MXO2 Mini on the internet and started wondering which features this has when it comes to vMix.
1. Does it support vMix External Output like the BMs? This is not a dealbreaker as I already have enough DeckLink outputs.
2. Does it support simultaneous input and output other than loopback? (Compared to the intensities)
3. Does the software used have anything to do with DHCP compability (will vMix display HDCP inputs)?
4. Since the unit I'm thinking of buying only comes with the Expresscard 34, and an PCI-e to Expresscard adapter is a lot cheaper than a PCI-e host card, will the cheap adapter work?
Any help or insight within this unit is much appreciated.
Cheers, Håvard
