lestra
#1 Posted : Tuesday, June 23, 2020 4:18:46 PM(UTC)
lestra
Saint Kitts And Nevis
Hi. I have to read manual in deep but I need quick info please. How to bring two of these cameras to vmix? There is only one ip adress for camera connect and control. Do I have to use hdmi connection and lan only for pan/zoom? I am very confused, please point me in the right direction.
boris9831
#2 Posted : Monday, June 29, 2020 10:57:17 AM(UTC)
boris9831
You need to set the cameras to different IP address'. If these cameras use the same PTZ command structure as PTZoptics then you should be able to set the Minrray to PTZoptics with the IP you assigned them.
lestra
#3 Posted : Monday, June 29, 2020 5:17:16 PM(UTC)
lestra
Boris9831 thanks. That is exactly what I have done and everything works.
jaialai
#4 Posted : Tuesday, July 7, 2020 9:26:09 PM(UTC)
jaialai
I have a Minrray PTZ camera and I have tried to move it using the PTZ function of the VMIX but impossible to connect the Minrray PTZ to the VMIX. I have spoken to another colleague who has the same camera and the same thing happens to him. Could it be the latest VMIX update? The latest Windows update?
stuartvideo
#5 Posted : Saturday, August 8, 2020 1:16:53 PM(UTC)
stuartvideo
I have a Minrray PTZ camera UV510A-05 camera work in other software and worked before . today only top part screen and garbled video? NDI same thing? please help .
update or something?
