openaspace
#1 Posted : Saturday, June 20, 2020 1:41:05 AM(UTC)
openaspace
Italy
Helloo :)
I have cameras at 50i , but i need to stream with vmix at 25p.
What the correct procedure?
50i is 25fps interlaced, I can works with a Vmix project at 25p adding cameras at 50i deselecting the interlaced option
and have the video inputs correctly?
Thank you.
#2 Posted : Saturday, June 20, 2020 2:25:40 AM(UTC)
Create a 1080p25 project
Add your cams with 1080i50 and tick the interlaced checkbox
That's it ! Now everything you do in vMix is 1080p25
openaspace
#3 Posted : Saturday, June 20, 2020 2:28:09 AM(UTC)
openaspace
Italy
I have tested now a vimeo stream
with project at 50i and external out , streaming ticker selection, to 25p and the recorded stream works correctly without interlacing errors.
I will try with the 25p without "i" selection and trying to stream.
Thank you.
