	Does audio solo go out over the live mix?
  Thanks: 2 times Was thanked: 4 time(s) in 4 post(s)
                The help menu refers to the solo ability, which I'm hoping will solve my issue. I have multiple people coming in over Video Call, and I want to set up their audio levels before they go out live. If I put all of them in solo, can I set levels while other audio (pre-show music) plays out over the live mix to viewers? UPDATE: Found the answer in the Audio Tutorial #4 at 8:44
 Joined: 7/28/2019(UTC) Posts: 351  Location: Santa Rosa Thanks: 1 times Was thanked: 53 time(s) in 51 post(s)
                Solo is simply a way to isolate an input in your headphones. It also allows you to hear an input that has its audio muted. So no, soloing a muted input will not put it live. If you don’t see levels next to your program window, it’s not live.
