mfariss
#1 Posted : Tuesday, June 16, 2020 5:57:23 AM(UTC)
mfariss
More Outputs
More Outputs
More Outputs
Should not have to burn an output to get program mix into the recorder and multicorder. Anywhere output 1-4 is available, Program should be available also
And more outputs
#2 Posted : Tuesday, June 16, 2020 8:22:50 AM(UTC)
how are you burning an output when it's the first option to record the program mix (output1)
also you have more NDI outputs that can be recorded externally
