Rank:: Advanced Member
Thanks: 3 times Was thanked: 13 time(s) in 3 post(s)
Two weeks in a row I started streaming and discovered that vMix Deinterlacing wasn't working. After the stream I disabled and enabled the setting and it started working again. Are others seeing this? I may report this as a bug unless there is something I'm missing.
AFAIK deinterlacing works perfectly in vMix.
Elaborate a little more on your setup and settings and maybe illustrate your statements with examples if you want help. 'Cos you're certainly missing something indeed !
Deinterlacing while enabled (in settings) isn't always applied at launch, it requires me to disable and enable deinterlacing for it to be applied.
First stream of the day wasn't deinterlacing, after the stream completed I checked settings and it was indeed enabled. I disabled, restarted, enabled, restarted. Second stream of the day was fine and deinterlacing worked perfectly.
There is a possibility this is related to upgrading to newer versions but can't be sure until next weekend and/or there is another upgrade.
Joined: 4/8/2020(UTC) Posts: 10  Location: Belgrade Was thanked: 1 time(s) in 1 post(s)
Vmix deinterlacing is far from perfect. Blend deinterlacing produce blinking effect. I try jadiff x2 in VLC player, and it is much better than blend in vmix. Unfortunately Martin said to me that there is no plan for adding yadiff in vmix in the future. That is so bad for us who uses deinterlacing very often.
I've confirmed this issue only occurs when updating vMix. Originally Posted by: vmixusersrb  I try jadiff x2 in VLC player, and it is much better than blend in vmix. What is needed to use this, just install VLC on the system?
