Multiple mixes handling and MIDI out question
Hello everyone!
I have some newbie questions:
1. What is the best way to create a simple project, where there are 4 different screens, each of them should have separate mix controllable via vMix. I started a simple test with 5 different videos as inputs. My aim is to play these videos sequentially, each of them on separate screen, except the last one, which should play on all screens. So my first idea - I configured all available 4 NDI outputs as inputs (Output1 is Input1, Output2 is Iutput2 and so on) and made some simple triggers on each input (OnCompletion Cut to next clip with certain delay and marked the Mix number where it should be). Everything is working except the last one, obviously. I can make a SetOutput trigger to switch 2-4 outputs as I want, but not the main (first) output. And what if I have more videos/screens - let's say 8 or more, should I have more vMix instances running to achieve this?
2. Project is the same as above, but now I need vMix to send a specific MIDI note before each video starts playing. I have Novation Zero SL MkII MIDI controller connected, working perfectly to control vMix, but can I run it opposite way using MIDI out port at the same time and how?
Thank you in advance!
