Poll for more two More audio Busses
Joined: 6/2/2020(UTC) Posts: 67   Location: Berlin Thanks: 8 times Was thanked: 9 time(s) in 8 post(s)
Hello i would to ask if someone else then me need more audio busses?
If i use all 8 calls and laet the calls speak to each other i need all 8 busses to konfigure a n-1 for each caller.
but i also need two to three busses for my Broadcast facility.
I would use BusA for Voices routed to Master (With EQ Plugins and campressor etc). Then BusB for Video CLips with a soft Peak limiter routed to Master.
Also using BusC to then BusJ for the send backt to callers.
And a least i nead on bus as a monitor wedge for the studio moderator.
Who also works like this (if he has the full set ov audio mixing desk and videoswitcher)? I would like to have the ability to use these logic in vMix because it is safe for Feedback. Aslo it cant be that complicated for a modern pc to calculate three more audio busses.
Greetings
Joined: 5/10/2020(UTC) Posts: 104   Location: Sacramento, California Thanks: 13 times Was thanked: 5 time(s) in 5 post(s)
Originally Posted by: Paul Fuhrmann  Hello i would to ask if someone else then me need more audio busses?
Greetings Paul, if your guests all connect with vMix Call, you don't have to generate Mix Minus for them, vMix does it automatically. But, yes, I could use more audio busses.
Hello Geoff B,
that is interesting new information to that mix minis is done automatically. Do you have an info resource for me?
What is the Source the automatic works, only master or can a Stack audio through busses and then to master and the auto mix minus will work? I Ask this because i use bussA to to process speech (eith some plugins) and bussB to collect all conserved audio (video and jingles) with nearly no procrssing. The master is only hosting metering plugins.
Also is it possible to create an „conference“ with the automatic logic? So callerA can talk to callerB and callerC with mix minus directly even if they are not in programm?
Thanks for your info allready.
Joined: 2/16/2017(UTC) Posts: 125   Thanks: 25 times Was thanked: 25 time(s) in 18 post(s)
As usual, it's in the manual...
Auto Mix Minus technology automatically handles the audio mixing for each guest, preventing echo and saving time.
Thanks for your info allready. vMix automatically generates a mix-minus for every Video Call, regardless of which bus (Master, BusA, etc.) you send to that caller.
