Audio buses contribution levels
Joined: 6/1/2020(UTC) Posts: 27  Location: Spain Thanks: 1 times Was thanked: 7 time(s) in 4 post(s)
We can decide which inputs go to either bus A or bus B but, can we adjust the level of each bus contribution?
Scenario:
I have a Vmix call and I assign the return audio of the guest to BUS A. That way, I can speak with the guest and not affecting the streaming output. But I would like the guest to hear me (bus A) + master. Moreover, I would like to adjust the audio levels so that my voice is louder than master. Obviously without affecting the streaming levels.
Is that possible?
Thanks!
@ robert5521
I would suggest bringing program audio back in via NDI, reduce the level and send it to Bus B. Then feed your voice to Bus B at normal volume and send your caller Bus B for audio return.
Wow, that's a very clever response. Makes complete sense, I will try it out. Thanks!
