Multi network device - Web controller picks the wrong adaptor
Joined: 5/29/2020(UTC) Posts: 4  Location: Glasgow Thanks: 2 times Was thanked: 1 time(s) in 1 post(s)
Maybe this is an enhancement request.
When using the web controller, it seems to pick the last NIC adaptor in present in the system. In my case, it is a VMware virtual NIC.
Would it be possible to get the Webcontroller to have a dropdown list of available NICs in the system? I have seen a few questions about how to configure it and how to set the routing etc. However, the problem is not setting the routing, the problem is just being able to pick the correct interface for the service to bind to. It currently chooses, but chooses wrong.
Config below..
Ethernet adapter Ethernet 2:
Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . :
Ethernet adapter Ethernet 3:
Connection-specific DNS Suffix . : Link-local IPv6 Address . . . . . : fe80::6d:a623:40b0:d2c2%17 IPv4 Address. . . . . . . . . . . : 192.168.0.50 Subnet Mask . . . . . . . . . . . : 255.255.255.0 Default Gateway . . . . . . . . . : 192.168.0.1
Ethernet adapter VMware Network Adapter VMnet1:
Connection-specific DNS Suffix . : Link-local IPv6 Address . . . . . : fe80::68f0:d54f:1221:7293%19 IPv4 Address. . . . . . . . . . . : 192.168.134.1 Subnet Mask . . . . . . . . . . . : 255.255.255.0 Default Gateway . . . . . . . . . :
Ethernet adapter VMware Network Adapter VMnet8:
Connection-specific DNS Suffix . : Link-local IPv6 Address . . . . . : fe80::8152:ec9e:2cfd:4b9%9 IPv4 Address. . . . . . . . . . . : 192.168.220.1 Subnet Mask . . . . . . . . . . . : 255.255.255.0 Default Gateway . . . . . . . . . :
Ethernet adapter Bluetooth Network Connection:
Joined: 1/13/2010(UTC) Posts: 5,344  Location: Gold Coast, Australia Was thanked: 4746 time(s) in 1631 post(s)
Thank you.
I think it would clear it up a bit if it would list all the addresses it is listening on.
What Martin wanted to say is that if you have three NICs all would work. vMix just picks one of it to display. NIC1:[IP:Port] NIC2: [IP:Port] NIC3: [IP:Port] You can also use NAT from outside to control vmix
 1 user thanked mavik for this useful post.
