Hallaman
#1 Posted : Monday, May 25, 2020 10:22:15 AM(UTC)
Hallaman
Hi All,
I'm looking at options of giving a Vmix Call caller the ability to activate certain shortcuts during a production.
What would be great is the ability to present buttons on the call webpage to the caller so they can press them while in the call interface.
Currently we can do this function by using the API and or Richards Panel Builder app, but this means the caller is having to use another device and we have to set that up on a case by case basis.
For instance, Caller is in call but would like to switch the return vision. Either the switch operator can do this, or the caller could choose via Panel or API (Another web interface, Stream deck etc etc)
Another scenario is that the caller is doing remote commentary. They need a talk to director button (this is similar to the PTT director to Caller that Tim did a Youtube video on) If this was in the Call interface, it is much cleaner.
One thought is embedding the Call page in an iFrame within another web page. But that starts to get messy with all the access that Call needs to the callers peripherals.
Anyway, anyone got a way to do this already or should I add it to the feature request list.
Cheers,
JB
