m_elias
#1 Posted : Thursday, May 21, 2020 11:34:01 PM(UTC)
m_elias
Canada
My understanding is that vMix requires the user to manually set the correct input resolution and frame rate. Is there some built-in or other software options for scanning/testing the input to check what its actual res & frame rate are? I know, I should know what I have the camera's output set to but some cameras' settings are tricky and have multiple parameter changes needed before it's actually outputting what you want, I'd like a simple method to verify it.
