shilolo
#1 Posted : Tuesday, May 19, 2020 5:50:36 PM(UTC)
shilolo
Israel
hi
someone from his experiences can tell me what the best settings to my GH4 camera (i stream 1080)
in 30 fps the output is not smooth view..
KnKproductions
#2 Posted : Wednesday, May 20, 2020 2:10:03 AM(UTC)
KnKproductions
Originally Posted by: shilolo Go to Quoted Post
hi
Here's a few things to try:
-change your shutter speed to 1/60 and adjust iris/aperture and iso to get the desired exposure
-change your output fps to 60fps, move the shutter to 1/120 and adjust iris/aperture and iso to get the desired exposure
That should help smooth it out the picture if the camera is stationary.
If you're handholding the camera, still do the above steps and also turn on the image stabilization or try using a gimbal or glidecam to steady the camera. If you're able to have a lens with built-in image stabilization, in conjuction with camera's built-in stabilization, and have all that on a gimbal, you will have the most stable handheld image possible.
