dperaltajr
#1 Posted : Monday, May 18, 2020 2:31:21 AM(UTC)
dperaltajr
Hi Guys, not sure if this has been suggested before, searched and didnt see it specifically.
If there can be a way to set different audio delays for Different Outputs and Busses
Use Case:
Using Output 1 (PGM), Fullscreen out, AV is synced for AV Distro around the House
using Output 1 going via NDI feeding Zoom/Webex, AV is slightly off sync. If there's a way to compensate for the NDI output going into NDI Virtual Cam, or even setting a delay via Bus/Different Output that would help.
Thanks!
bubu2110
#2 Posted : Monday, March 14, 2022 6:27:40 AM(UTC)
bubu2110
Germany
Hey dperaltajr,
I have the same problem like you.
I will show you my own workaround:
Input 1 is a vMix Call.
Input 1 goes to Master-Audio and into the stream.
I also put Input 1 to the Output 3 and activate NDI on it.
I added the Output3-NDI to my Input 2. And on this Input I can use a separate delay and send it to you Audio Bus.
I hope I can help you.
Peter Berglund
#3 Posted : Friday, April 1, 2022 7:55:06 PM(UTC)
Peter Berglund
Sweden
It would be very handy if audio delay was available for the output buses in the same way that vMix provides for any input. Unfortunately that is not the case. My workaround is to use a simple VST3 audio delay plug-in for my output buses. Even if it is a "work-around" it works great!
/Peter
Guest (4)
