Joined: 5/9/2020(UTC) Posts: 18  Location: Cologne Thanks: 1 times Was thanked: 3 time(s) in 2 post(s)
One simple request: A button that turns off all enabled solos. That could be the indicator that shows up on the right of "Fullscreen" when one or more solos are active. Just make that the solo-cancel-button.
Most all real audio desks have one of these. They come handy if you want to cancel solo and return to listening the main bus, but cannot find the channel that has solo turned on.
Thanks, Michael
 1 user thanked mixmexmax for this useful post.
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: mixmexmax  One simple request: A button that turns off all enabled solos. That could be the indicator that shows up on the right of "Fullscreen" when one or more solos are active. Just make that the solo-cancel-button.
Thanks, Michael seperate from the SoloOn and OFF shortcut options one can poll the API XML to check which are on or off and act accordingly (script)
Joined: 4/3/2020(UTC) Posts: 38  Location: Canterbury Thanks: 4 times Was thanked: 4 time(s) in 4 post(s)
Yes - I agree! I've been caught out in a hurry trying to find 3 or 4 Solo'd sources to disable them! Also I noticed earlier that when you solo a bus, you dont get the indication at the top by Full Screen - it only seems to work on inputs! Very confusing! Can someone else back me up on that?
