Higher system usage in 64bit mode?
Joined: 2/27/2013(UTC) Posts: 312   Thanks: 8 times Was thanked: 78 time(s) in 43 post(s)
So we have been having some odd behavior in vMix while in the 64bit mode. We have 2 cameras at 1080i60 and a screen capture over the network. Recently it seems like in the latest update that we did, we have been running at higher CPU and render times in 64bit mode.
While we are recording and streaming we sometimes peak at upwards of 35% CPU and 35 to 39ms render time. If we switch to the 32bit version, that drops to around 15-18% CPU and 18-24ms render time.
I would think that the render time and the CPU would go down in the 64bit version. Any idea on why vMix would do that?
Joined: 1/13/2010(UTC) Posts: 5,325  Location: Gold Coast, Australia Was thanked: 4728 time(s) in 1620 post(s)
64bit and 32bit versions of vMix each can be their settings set independently. Have a look through the settings of each and see if you can identify some differences. The following guide will help: http://www.vmix.com.au/k...2/optimising-performanceRegards, Martin vMix
