Chromakey blue color support?.
Hello, In the current vmix Chromakey green color can only be supported, blue chromakey capabilities can it be? Especially in Korea, chromakey Kroger feedback talktosonic talktowendys blue studio uses a lot. Chromakey blue color in the next version support available? thanks iosman
Joined: 12/27/2012(UTC) Posts: 5,521  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
you can select any color to be used , click on the eyedropper
Blue used in Korea but you are from Albania ? would that be the same blue ? ;-)
