Showcase
Daily Poetry Readings
Joined: 4/6/2019(UTC) Posts: 95  Location: Florida Thanks: 10 times Was thanked: 13 time(s) in 11 post(s)
So far, have had it going for over a month and it's getting easier to lay down a recording without mistakes. The whole goal is to read it as flawless as I can, without dramatic effect so the poems can do all the talking. It's all done in vMix and controlled with a midi fighter twister midi controller to activate the sequences, overlays, and volume control. https://www.youtube.com/...L4QHakTCuQKEbqWUQ/videosThe DIY teleprompter was originally put together so I could look at the camera and conference/guest calls at the same time. That works well too, although I sure could use a real piece of teleprompter glass instead of this regular glass pane from a picture frame. Camera: Zcam E2 w/ Rokinon 24mm T2 NDI: Magewell Pro Convert HDMI Plus Mic: Beyerdynamic DT 797 PV-250 Audio Interface: Mackie 1402 VLZpro and Zoom H6 (For now, have a better/smaller setup coming) Teleprompt: www.zacue.comMidi Control: DJ Tech Tools Midi Fighter Twister
Showcase
