hmastet
#1 Posted : Tuesday, May 12, 2020 5:19:41 PM(UTC)
hmastet
So right now in vMix you can select separate mono for your channels which is great, and assign outputs via the channel matrix.
However, you cannot assign vst plugins to separate channels of that audio track.
This is the classic guitar/singer problem. Now if it was NDI, no problem, I'd just run two instances of NDI inputs, one audio only and take the very small quality hit.
However this could work on SRT but would require lots more setup time on larix broadcaster.
Any advice?
