avs&cams
#1 Posted : Tuesday, May 12, 2020 1:03:43 AM(UTC)
avs&cams
Slovakia
I would like to ask you about my problem. In the performance system vMix doesn't support my Nvidia GPU just integrade Intel UHD630.
Any solutions?
Thank you for help.
avsc
xaver
#2 Posted : Tuesday, May 12, 2020 1:46:39 AM(UTC)
xaver
can you change the GPU for vMix before you start vMix?
right click to the shortcut on the desktop, there shoule be "start with GPU" or someting else
avs&cams
#3 Posted : Tuesday, May 12, 2020 5:10:24 AM(UTC)
avs&cams
Slovakia
Hello Sir,
you have right. I forgot for this elementary setting. :)))
avsc
