aircooled76@gmail.com
#1 Posted : Monday, May 11, 2020 9:04:11 PM(UTC)
Hi Everyone,
I believe I have found a bug with the Activators feature.
I have an XKeys T-Bar 124 and an Akai APC Mini. I mapped the XKeys in Activators and Shortcuts to channel 16.
When I press the bottom row of XKeys from left to right (starting note 7), the right hand column of the APC Mini flashes Green (Starting note 7.)
When pressing the APC Mini buttons it has no effect on the XKeys activators. It does not matter what the default values are for the APC keys.
The shortcuts seem to be functioning properly.
Not sure if anyone else is using these two bits of kit can confirm?
TonyO
#2 Posted : Saturday, July 3, 2021 8:39:06 AM(UTC)
TonyO
I am experiencing the same issue. I have XKeys on channel 2, and the APCmini uses 1. No extraneous lights on the XKeys, but many on the APCmini.
Basically, I am seeing that when button (2:7) on the XKeys is supposed to light up, button (1:7) on the APCmini also lights up.
Any help with this would be appreciated!
Thanks,
Tony
