Assolollo
#1 Posted : Monday, May 11, 2020 2:52:27 AM(UTC)
Assolollo
Italy
I'm just starting to use Vmix, I got the 1 Call version.
My problem is that when I stream on Yuotube without Call, the flow goes quite well, but as soon as I insert a Call, it slows down everything and also overloads the CPU, I specify that I don't have a big PC and my bandwidth upload is 1Mbps :(
Do you think I have no hope or is there any tip to fix the issue?
#2 Posted : Monday, May 11, 2020 3:05:52 AM(UTC)
There is hope...
with bigger pc and more bandwidth
Assolollo
#3 Posted : Monday, May 11, 2020 5:26:49 AM(UTC)
Assolollo
Italy
Originally Posted by: doggy Go to Quoted Post
There is hope...
That much I've already figured out.
Vince Beck
#4 Posted : Monday, May 11, 2020 6:59:42 AM(UTC)
Vince Beck
Then you know what to do :-)
The bare minimum for bandwidth with streaming and one call would be 5Mbps up and down. That’s assuming you are the only one on that line with no other machine running and that you are streaming at a really low quality like 1500 Kbps.
No recommendation on PC other than the reference machines listed on this site.
thanks 1 user thanked Vince Beck for this useful post.
doggy on 5/11/2020(UTC)
