mixmexmax
#1 Posted : Saturday, May 9, 2020 3:52:38 AM(UTC)
mixmexmax
Germany
Hi all,
I would like to produce a rtmp stream in 1920x720px. Vmix does not offer custom output sizes, right? I am now looking into cropping the stream in FFMPEG. There is a dropdown in the settings called "aspect Ratio/Crop". This has Original, Square and 9:16 as options. If I choose these, the ffmpeg gets a crop-command in the command line, you can check it in the logs. For 9:16 it says: "scale=1920:1080,crop=608:1080".
Now the question: Is there any way I can get my desired aspect ratio/crop of 16:6, so that the resulting output is 1920x720px?
Any ideas welcome!
Mike
MartLeib
#2 Posted : Saturday, May 9, 2020 8:56:15 AM(UTC)
MartLeib
Estonia
Feed your vMix output to OBS. You can define any resolution there and crop it as you like.
