andrewgfd
#1 Posted : Wednesday, May 6, 2020 2:24:28 AM(UTC)
andrewgfd
Hi there, newbie here. Have been evaluating vMix over the last couple of weeks with the trial, and have been very impressed. My user case is sporadic non-commercial use, so am keen to work out what the right long term version for me to purchase. The HD package is probably what I am looking at, however, I have a question about the GT graphics packages.
In using vMix, I have either created my own graphic template in GT Designer, and also adapted some of the existing templates and made them bespoke. I assume as part of the trial, this is the Advanced version. My question is what can be done with the Standard tool, and what functionality would I loose? Can I still create my own templates, or modify them in the GT Standard product and create a .gtzip file? Or is it limited to just using existing templates and only being able to make the minor adjustments within the main vMix application?
Any thoughts welcome.
Thanks, Andrew.
#2 Posted : Wednesday, May 6, 2020 2:30:20 AM(UTC)
No self designed animations , can design static titles !
also see
https://www.vmix.com/purchase/#comparisontable
andrewgfd on 5/6/2020(UTC)
