mattisgood80
#1 Posted : Monday, May 4, 2020 7:28:44 PM(UTC)
mattisgood80
Hello, I'm looking to integrate the capture of my Zoom screen in gallery display but without the black background. I want to integrate it into my skin like this. Thank you for your explanations
Zoom
Narcogen
#2 Posted : Tuesday, May 5, 2020 12:22:35 AM(UTC)
Narcogen
Not really possible. Zoom does not provide independent camera feeds, and the position of various participants on the screen is not consistent and cannot be fully reliably controlled when participants join and leave.
The only way to do what you want is a series of local desktop captures, cropped and sized how you like with the various cameras in a MultiView. Unlike Skype's NDI integration, Zoom doesn't provide per-participant video, you've only got the window or display to capture.
mattisgood80
#3 Posted : Tuesday, May 5, 2020 12:34:21 AM(UTC)
mattisgood80
I confirm that it is possible to do so. look at this link.
https://www.facebook.com...videos/225941985492617/?
Vince Beck
#4 Posted : Tuesday, May 5, 2020 12:45:49 AM(UTC)
Vince Beck
Yes, you can with zoom rooms. You can create presets for camera positions.
mattisgood80
#5 Posted : Tuesday, May 5, 2020 12:48:50 AM(UTC)
mattisgood80
but how is the transparency of the background in vmix managed? did you watch the link with the video?
Vince Beck
#6 Posted : Tuesday, May 5, 2020 1:37:13 AM(UTC)
Vince Beck
Not sure if that can be done with standard Zoom? But with Zoom rooms, you can have a background behind the windows. Just put a green image and key it out in VMix. It might be worth even trying a transparent png and see if Alpha is passed through NDI.
mattisgood80
#7 Posted : Tuesday, May 5, 2020 1:46:07 AM(UTC)
mattisgood80
https://www.casimages.co...504055517466182.png.html
this is how it is managed by the company that set up the live. I have absolutely no idea how it is managed to manage the Alpha
Vince Beck
#8 Posted : Tuesday, May 5, 2020 2:03:30 AM(UTC)
Vince Beck
I’ll expriment some today, but I bet it’s either a galley keyed out background or a transparent PNG background.
Vince Beck
#9 Posted : Tuesday, May 5, 2020 2:08:35 AM(UTC)
Vince Beck
Also, using Zoom Room like these guys did, your pips are static, so you can overlay them in VMix and which way you like and crop away.
mattisgood80
#10 Posted : Tuesday, May 5, 2020 2:08:54 AM(UTC)
mattisgood80
more it uses zoom and not zoom room because the gense connects from their smartphone. In zoom can we change the background of the gallery?
mattisgood80
#11 Posted : Tuesday, May 5, 2020 3:06:44 AM(UTC)
mattisgood80
yes this can be a solution but it is not the principle in the video that i sent you. because it's not zoom room
