Markarkark
#1 Posted : Monday, May 4, 2020 2:45:41 PM(UTC)
Markarkark
Views messages in topic : 6
Is there a way to set up two or more Mevos to the system. My thought would be to have two tablets or ipads with a mevo camera on each, then put mevo one on camera one, mevo two on camera two etc. Then pick my shot on the pad that is not active. Can this be done?
FredHarder
#2 Posted : Friday, May 8, 2020 9:21:35 AM(UTC)
FredHarder
I would think this would work.
Would setup 2 different inputs as RTMP servers and then point the 2 mevos to those locations.
I think the one possible gotcha would be the lag in the stream and syncing issues as you cut from one cam to the other. Admittedly I haven't tried a setup like this so I can't say for sure.
thanks 1 user thanked FredHarder for this useful post.
Markarkark on 5/14/2020(UTC)
marcuscole
#3 Posted : Wednesday, May 20, 2020 11:21:06 AM(UTC)
marcuscole
The new Mevo Start camera supports NDI. So you could use it as a source as long as it was connected to your network. https://mevo.com/mevo-start/
Suprisingly, the new Mevo Plus does not support NDI.
AlanZ
#4 Posted : Wednesday, May 20, 2020 1:46:39 PM(UTC)
AlanZ
Note that the Mevo Plus has been out for quite a while (it has improved WI-FI compared to the original Mevo). I have one, and I was also an early adopter of the Mevo Start... the Start works quite well with vMix.
dstephens
#5 Posted : Thursday, December 24, 2020 11:23:27 AM(UTC)
dstephens
I just purchased a Mevo Start with the hopes of live streaming with Vmix either as the sole camera or as an additional camera. I have read that one can use NDI to record using Vmix but I am not at all sure that I can live stream using NDI and Vmix. Can anyone help me with this question? Thanks!
#6 Posted : Thursday, December 24, 2020 5:44:58 PM(UTC)
Streaming is vMix main role and supports NDI!
Since apparently you did not even visit vMix website to read about what vMix is and does and before you ask any other question like "can I write with my pen?" please click on the links below:
- Website: https://www.vmix.com/
- YouTube: https://www.youtube.com/user/vmixcomau
- Knowledge Base : https://www.vmix.com/knowledgebase/
- Manual : https://www.vmix.com/help/
Then you can have fun with vMix, NDI and your new Mevo camera !
