Any way to automatically import settings file?
I typically have to switch between different video formats (SD to HD) quite frequently, which means having to update the system settings. I notice there are import and export buttons in the settings. But any time there is a video format switch I need to start vmix, import the settings i want, close it and start with the appropriate preset. It would be great if there was a way to automatically import the settings. Perhaps a command line argument on startup?
