I recently acquired a xk-60 kvm version and I am trying to integrate it to vmix (v23.0.0.51). I have no issue with using shortcuts via MIDI, but when i try and use the "Activators" to control the backlights I get some screwy results. First, I have to enable "x-key Controller". If i only enable my controller from the list, nothing works. Second, if I set the following: Control: Note Channel:1 Note:0 to 0 Event: Default Type:X-Key Button LED (Blue)
it lights up the blue backlight behind button #1 ~ as expected .... BUT... If I change the color to RED, the backlight behind button #49 turns RED (and the blue turns off).
I have reset the device to factory default and reloaded the midi driver, but nothing seems to change it.
hmmmm
