Hi
I took a KONA 3G & a BMD Decklink Extreme out of happily working vMix machine (AMD W8000 GPU) and put in a differnet, happily working, vMix machine (AMD WX7100 GPU), replacing a DataPath SDI2 and a DeltaVision card. On restart, no display output, no fan turning on GPU but managed to VNC into the machine to see it didnt even see the GPU in device manager. A bit of fault finding led me to the KONA card.
Any one able to shed any light on what might be causing the issue?
I've worked aorund it for now but will be trying to sort it out as it's one of the more featured cards I have available at the moment.
Kevin
