contact.jthomaskay@gmail.com
#1 Posted : Wednesday, April 29, 2020 3:07:35 PM(UTC)
I am new to the vMix format. I want to have an onboarding system where I talk to callers in various green rooms via busses.
Currently, I have an M-Audio 2 Channel Mobile Pre working with vMix. I have one microphone (Chan 1) as the moderator and the second (Chan 2) to talk to the green rooms.
I would like to use busses A & B as separate green rooms. I would have Bus A as the green room for the panel to talk to each other before they went on. Bus B would be for me to onboard new arrivals one-to-one before I moved them into Bus A with the panel they would be with on the call.
Is this scenario doable? I am thinking of how Zoom does Breakout Rooms. Thanks.
#2 Posted : Wednesday, April 29, 2020 9:03:46 PM(UTC)
@ contact.jthomaskay@gmail.com
It's all about what Audio Source you send back to your Callers and what Busses are enabled for their mic, which can all be changed "on the fly" at any time.
