 Joined: 4/11/2020(UTC) Posts: 17 Thanks: 2 timesWas thanked: 1 time(s) in 1 post(s)
                Does anyone know of a way to have an activator light when an audio input is faded to zero or AudioOff?
 In addition, I made a script to import the latest video. Is there a way to add a category for the imported video to the script?
 Thanks for your help.
                OK I found the SelectCategory command, but any help with the audio activator question would be appreciated. |
                Can't seem to find the answer to my question above. Two ideas I have....Is it possible to use a Trigger to run an activator? Is it possible to add an activator to a script?
